Whats this connector for?
georob
Post Sat Mar 04, 2006 1:16 pm
Car died monday, changed fuel pump as thought that was the prob, nope
I noticed there is a plug from the same lead that plugs into the back of the icv that isnt connected, its at the side of the block
should this be connected soemwhere? whats it for?
no idea what the hell is wrong with the car, its driving me crazy :mad:
smithy318i
Post Sat Mar 04, 2006 1:30 pm
mine isnt connected too. forget about it.
Post Sat Mar 04, 2006 2:14 pm
Spare connector is for the carbon cannister control valve, which you don't have.
How dead is dead?
Check, with a 12V lamp, for 12V+ on the + terminal of the ignition coil when the ignition is on and when you are cranking.
Take a plug out, reconnect it to the lead and lay it on the rocker cover. Check that it sparks once every two turns of the engine when cranking.
Disconnect a fuel supply hose (one that comes from the filter) and check that petrol pumps out when cranking.
georob
Post Sat Mar 04, 2006 2:53 pm
Thanks Brian and smithy
Car all ok now, was a diamond shaped bit of shit in the line, renewed the line, all ok, woooohooooo
just another thing trying to dig it out
thanks again guys
