head problems
Guest
Post Wed Jan 12, 2005 2:35 pm
guys I need to fix the gasket on my 1984 3.20i with hartge conversion (I think the may have rebored the engine to 2.3), I am sending the head in to be engineered the only thing is I dont know exactly what the guys at hartge have done to the engine if the have rebored the engine would a standard 3.20i head fit (if my old one is cracked and I need to rplace it)
also would fitting a 2.5L head have any adverse effects?
needing some seriouse guidance! thanks 4 all the help, like the new look
E30Adam
Post Wed Jan 12, 2005 2:38 pm
Take measurements of your bores to determine if they've been increased. I didn't know Hartge even worked on a 320?? Have you got paperwork supporting this or did the last owner just tell you this?
Failing that, give Birds a call and if it was converted, they should have all details of your car and be able to tell you what was done to it.
If it turns out to be a stock bottom end, a 325 head will not work with the 320 bottom end.
Guest
Post Thu Jan 13, 2005 5:38 am
Dont have any paperwork regard the conversion, Im taking the previous owners word on it, when he had some work done on it his mech had to use parts for a 3.23 not a 3.20.
If it has been rebored to a 3.23 would a 3.25 head work? Also who are "Birds" and were would I find them as I am in the S.A. not the UK?
randomdave325
Random E30 Nutta
Post Thu Jan 13, 2005 9:10 am
just e mail hartge and if it is one of their cars they will tell you all you need to know. they will email you with details of the closest hartge dealer.
http://www.hartge.de
As adam said it's birds uk over here and they were most helpful with mine. they've lost the records of the early stuff (or can't be bothered to find it) when they computerised the system. but luckily kevin bird is a very nice man with a very good memory and identifyed mine through a few unique things. i.e pre hartge manifold and strut brace (as they were not avaliable back then).
apparantly mine was one of the first 5 they did! give them a bell on 01895 810850 if you get stuck. but bear in mind they are usually very busy!
The current fleet!
1990 318iS
1984 528ise
1987 325i sport
1990 325i cabrio
1987 m3 s50b30
'Turning money into noise' :)
schmick325
Post Thu Jan 13, 2005 9:15 am
Strange conversion if its been bored. the 320i and 323i share the same block and bore size.
Guest
Post Thu Jan 13, 2005 3:03 pm
why exactly wont a 3.25 head fit on a 3.20 are the valves smaller?
E30Adam
Post Thu Jan 13, 2005 3:15 pm
bobbin320 wrote:why exactly wont a 3.25 head fit on a 3.20 are the valves smaller?
The combustion chambers are a different size.
Dom
Post Thu Jan 13, 2005 3:18 pm
so the 2.3l capacity is acheived through changing a few internals on the 320?
Guest
Post Fri Jan 28, 2005 6:30 am
Hey guys, Im Back! armed with a replacement c\head for my cab (skimmed, ported and most importantly not cracked), wich I intend on doing as soon as possible. like tomorrow.
Any way to the pointwhat is the easiest way of get the #1 piston to TDC I was checking through the manual, and came across the rotor arm trick when you, point the rotor arm in the direction that the #1 ignition lead would fit.
Only thing is I am not entirly sure I was checking the leads last night they are all different lengnths, but then I noticed that they were numbered (2-6) and I have two leads that are both numbered (6) and no lead numbered 1. Its thrown me off a bit. Do those numbers have any significance.
:lol:
