Help asa
georob
Post Fri Mar 03, 2006 3:00 pm
whats the part on the induction side thats after the afm, its got 2 hoses, one in one out, t shaped piece. part no. 0 280 140 524
Should this make a clicking sound?
eko
Old timer
Post Fri Mar 03, 2006 3:05 pm
ICV-idle control valve,and yes i think it should click!
georob
Post Fri Mar 03, 2006 3:06 pm
Thanx bud
Thing is craning ok, but still not starting
ARGHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH :mad:
eko
Old timer
Post Fri Mar 03, 2006 3:09 pm
Is fuel getting through?
Good spark?
georob
Post Fri Mar 03, 2006 3:11 pm
yip to both
she catches just, but not enough
eko
Old timer
Post Fri Mar 03, 2006 3:56 pm
crank sensor dirty/knackered?
Think this is one for Brianmoore :mad:
georob
Post Fri Mar 03, 2006 4:44 pm
where could i find that about in the enigne bay?
before it died, in 3rd she was spluttery as hell about 3-4k then cleared, about 2miles later it lost all power then cut out, belts are all ok, fuel pump ok, reaching the engine, getting a spark ok
one thing i noticed that wasnt there last night, the engine oil light is on, on the check panel, never done that before, theres oil in it, no leaks
the other poss thing is the fuel neck pipe needs replaced, wouldnt affect anything though would it?
eko
Old timer
Post Fri Mar 03, 2006 4:50 pm
Geprge im am no expert so can only guess!
Brian is definately the man you need to speak to.
Crank position sensor should i think be at the front of the engine pointing to the bottom pulley,it picks up signals and sends them to the ECU,might be worth wipping it out and giving it a clean,at least you can say you have done it if Brian asks/suggests that.
I was going to say maybe ECU fault but again only a guess?
Martinaston
Post Fri Mar 03, 2006 5:51 pm
Check the engine earth strap and give it a clean.
There is NO nucleus.
