Coolant Leak!
Cyruz
Ahhh HELP! As I was driving to school this morning I noticed a pool of coolant on the passenger side floor, it had dripped from under the center of the dash. I'll have a proper look when I get home anyone heard of this before?
Quaser
Sounds like it could be the heater matrix dude
Cyruz
Gah bastid evil thing! Anyone know how arkward these are to replace? I'm not paying a garage to do it thats for sure
, mainly due to my lack of money!
More likely to be the electric heater valve. Take the access panel off to the right of the glovebox and have a look. (Panel above glovebox comes off first).
Easy enough to change, but don't lose the little square nuts. Tape them in place when you refit.
You do have a radiator pressure cap with a yellow bottom, don't you??!!
Cyruz
I remember reading somewhere about a yellow bottoms raditor cap. Do you ment the cap on the overflow tank because the radiator doesn't have a cap?
Vavle shouldn't be to hard as the car is stripped and there is no glove box
Yes. I wrote radiator pressure cap to avoid confusing people.Cyruz wrote:. Do you ment the cap on the overflow tank because the radiator doesn't have a cap?
Presurises the radiator, where ever it's actually fitted.
