pulling to one side
jordano
Post Tue Feb 28, 2006 7:17 pm
i have an 89 325i cab and whenever i go over any kind of bumb or dip in the road whilst driving the car pulls to the left and the problem seems to be coming from the drivers side front wheel, any ideas what could be causing this????
worrying is like a rocking chair, it gives you something to do but it never really gets you anywhere
stuartgallafant
Post Tue Feb 28, 2006 7:51 pm
loose wheel bolts, knackered wheel bearing, loose tie-rods in the steering rack, anti-roll bar dive links, f*ck*d strut, low tyre pressures
that just a start at things to check...
jordano
Post Tue Feb 28, 2006 7:53 pm
ive jst replaced the rear shockers as they were fxxxd so im gna put new struts onm the front see if tht solves it
cheers
mk1chopper
Post Tue Feb 28, 2006 7:59 pm
Check the tyre pressure thats what was causing my 318 to pull to the left.
jordano
Post Tue Feb 28, 2006 8:57 pm
without checking i can say defo isnt tyre pressure as it is fne unless i go over a bump
