Speedometer
Lumpy
Post Tue Feb 28, 2006 5:39 pm
:mad:
My speedometer quit on my 86 320i. I was wondering if anyone knew where the speed control unit is on this car. It is an electronic speedo and i don;t think it's broken.
daveyw
Post Tue Feb 28, 2006 6:25 pm
speed sensor wires on the diff. these are bad for breaking i was told by someone on here.
Post Tue Feb 28, 2006 6:27 pm
it's electronic mate, there is a plug on the back of your diff on the right hand side, usually the wires running to the plug break eithre as they enter the plug or a foot or so away.
Best thing to do is rape some wire from a breaker, make sure you cut as much away as possible, at least 12", then splice in, solder if possible.
If you need a plug for any reason then the front fog plugs are the same.
Lumpy
Post Fri Mar 03, 2006 11:01 pm
Is There Any Way to test the speed sender at the speedometer. Maybe with a ometer
