my brake lining wear light is just starting to flicker...
i know it's a bit lazy to ask rather than look but... does this light take a feed from the rear brakes as well? only i had the front wheels off at the weekend and the front pads looked fine. i've only ever encountered this light working on the front wheels only before now.
gareth
johnono
ine flickers too, when the brakes become excesevly wet.
had the same happen on my old 2.dr also.
sensors front right, and rear left (?i think?)
Pad wear sensor is on front left brake only on drum rear braked cars, and on rear righr on all disc braked cars. If both pad sensors are OK and the plugs and sockets are clean and pushed together properly, then see a recent thread where I explained the probable problem inside the instrument cluster.
E30WEZ
Brianmoooore wrote:Pad wear sensor is on front left brake only on drum rear braked cars, and on rear righr on all disc braked cars. If both pad sensors are OK and the plugs and sockets are clean and pushed together properly, then see a recent thread where I explained the probable problem inside the instrument cluster.
Here it is mate simple to do fixed mine
http://www.e30zone.co.uk/modules.php?na ... pic&t=2018
WEZ
gareth
excellent! i would never have thought to look there in a million years!
ta!
ta!
gareth
hmmm, got a funny feeling it's telling the truth now! the light flashes at the same speed as the wheels are turning!
new pads time then...
johnono
that could be coz uԚ´re disks are warped
Check the wire from the pad sensor isn't rubbing on the inside if the wheel rim.
gareth
guess what... the pad wear sensor wire was rubbing the wheel!
good call brian!
good call brian!
SVBMW
Following Brian Moores' advice I tested the dry joint theory
Smack the instrument binacle on the left hand side - Light goes on
Smack the instrument binacle on the righ hand side - Light goes off
So I have a crude, but tempory solution. roll on the dry weather so I can pull the instrument panel and fix it once and for all.
Brian is a god!!
Tris
Brian is a god!!
Tris
