Hi guys, need to remove some sound proofing to investigate wateter leakes ready for welding.
Anyone have any tips for removing this, is it a grinder job?
cheers fellas
Sound proofing removal.
oguz327
- Captain Armco
Use a heat gun and a wallpaper scraper mate, it will fall off
If you use a grinder you will regret it come cleaning up time
oguz327
- Captain Armco
nice bro,
anyone got a heat gun i can borrow
316eyes
About Ԛ£20 from B&Q for a decent Bosch example. Worth every penny - found dozens of uses for mine since I bought it. Even as a hairdrier when the Philips expired!!!!!!!!!
lukeb
you can just use ice packs. as in the bags of ice you buy from the shop. leave these on and it should just break up. ive not tried this method only used a heat hun before. but a heat gun leaves behind the sticky stuff on the floor, where as using ice doesn't.
