Inlet manifold (removal of)
Grantley
Post Wed Feb 22, 2006 7:19 pm
I'm thinking of taking off the rocker cover and inlet manifold and painting them, my problem is I havent ever taken the manifold off before and dont know what it involves. I've read all the bollocks in the manual and it does'nt exactly fill me with confidance, so what i'm asking is do any of you wise owls have a idiot's guide to getting the mother off without wrecking the old girls internals. Any advice appreciated :thumb:
zaust
Zone day release
Post Wed Feb 22, 2006 8:04 pm
The more you can move out of the way the easy'er it is.
M30 Tech 1 Touring on gas.
chu346
Post Wed Feb 22, 2006 8:06 pm
Remove bolts then pull on the manifold. Simple.
What engine is it? on the m20 you'll need to pull down the spring loaded pipe. in the middle of the manifold. If you find it won't come off after removing all the bolts, you've missed one or more (easily done).
I can't remember there being anymore to it than that.
M5pilot
Post Wed Feb 22, 2006 11:13 pm
I hate removing and re fitting Inlet manifolds!
DazzyA
Post Thu Feb 23, 2006 5:25 pm
me too, I think the thermostat housing won't allow you to pull directly off because of the long middle bolt. It's a case of jiggling off the bolts then lifting up IIRC.
Pass me the spanner
Grantley
Post Thu Feb 23, 2006 7:01 pm
Would it be easier to mask up and paint it on the car ?
DazzyA
Post Thu Feb 23, 2006 7:22 pm
Yes.
Pass me the spanner
