Right size of tyre's?
jonbuoy
Post Wed Feb 22, 2006 4:58 pm
Now i've finished refurbing my BBS's i'm poddering which size to go with :?
I was gonna stick on 195/50R15V but i'm a bit worried how much the clock's will fall out. I need them to be cheap but do i really need to go to 205/60 ?
I don't want to even go to 205/50 but what does everyone else think?
Opinion's please my good zoner's :D
orangecurry
Post Wed Feb 22, 2006 5:02 pm
jonbuoy wrote: I was gonna stick on 195/50R15V but i'm a bit worried how much the clock's will fall out.
I no understand senor... do you mean the difference between true and indicated speed?
Kos
Post Wed Feb 22, 2006 5:03 pm
205/60 is the wrong size!!
205/55 the correct size, but 205/50 is the best as a few f the track day boys use them. falken or toyos are good and not too expensive either
jonbuoy
Post Wed Feb 22, 2006 5:04 pm
The radias of the tyre is smaller so will throw the speedo out but how much and can i get away with sticking the 195/50's on?
zaust
Zone day release
Post Wed Feb 22, 2006 5:08 pm
50 front 55 rear ???
why not.
M30 Tech 1 Touring on gas.
jonbuoy
Post Wed Feb 22, 2006 5:09 pm
Kos wrote:205/60 is the wrong size!!
I used to work in a tyre garage and i just went to one near me and the bloke turned round to me and said, "that's the wrong size!". I was like, fuck off, i can put what i like on my motor!
He looked through his little book and said the right size for the 318i is 205/60 but i'm sticking a 2.5 in it soon so i need the right size for that engine. Richard (TOURINGDADDY) is running 195/50 on his tourer 325i and it's great on them and can get hold of Toyo's for Ԛ£27 each.
What do you reckon Kos, go with 205?
orangecurry
get away with.... that's up to you
rolling diamter of 195/50/15 = 576mm
205/55/15 = 606.5mm
quite a big difference
Kos
Post Wed Feb 22, 2006 5:11 pm
its the size the seloc racers use, and a bit narrow a possibly low on grip for such a heavy car, but it makes for entertaining racing, you may find the back end loosing tracktion if the car is a 2.5 ???
jonbuoy
Post Wed Feb 22, 2006 5:36 pm
It was a bit lose in his tourer but that was the fun of it i spose but it cornered well unless you wanted the back to slide out.
My car is a 318i at the mo but is having the 2.5 in it within a mth's time. If i can afford the tyre's i'll go with the 205/50, it had them on before on my old 15's and was fine.
Cheer's for the replies lad's, much appreciated :thumb:
Kos
Post Wed Feb 22, 2006 6:22 pm
205/50 i recon buddy, the guy at the tyre place must have been looking at e36 sizes!!
i'm running 225/40 falkens with 16" rims and get loads more grip an the roads,10mph faster out of some bends on my fave roads over the last set of 15" with 205/55 15" pirelli 6000's.
the recomended size for 16" is 205/50 front and 225/45 rear but i said bollocks to that as well!! when 1 lower on the profile, but may change fronts to 215/45's for a bit more grip, as it undesteer a tad, but that will be after i change the suspensionn set up and ARB's which will alter the car completely so there may be no need for it
with lower profilesthere is less feeling of when the back will break away, with a 205/ 50 profile you can feel whens its about to go
205/50 front and rears mate with 15's
jonbuoy
Post Wed Feb 22, 2006 6:27 pm
Putting new bushes on my ARB made alot of difference to mine straight away :D
What ARB's are you going for?
Nice one fella, will sort that out asap :thumb:
Kos
Post Wed Feb 22, 2006 6:29 pm
any time, just let me know about these "drift nights" i have my old bottle caps on stand by!!!
Grantley
Post Wed Feb 22, 2006 6:44 pm
jonbuoy
Post Wed Feb 22, 2006 7:15 pm
Kos wrote:any time, just let me know about these "drift nights" i have my old bottle caps on stand by!!!
No prob's mate :D
Grantley wrote:Try using this link
http://www.miata.net/garage/tirecalcold.html
Cheer's mate, much appreciated :thumb:
Look's like i'd get away with 195/50's for drifting and 205/50 for normal and some drifting :D
Grantley
Post Wed Feb 22, 2006 7:26 pm
No bother mate, glad to help !
Lordschleife
Post Wed Feb 22, 2006 10:37 pm
You might want to have a look at the load indexs of the tyres too
The lowest recommended in the manual is 84, a typical 205/55/15 is 87-88
195/50/15 tend to be around 82
Otherwise I'd have probably bolted a set of 195/50/15 Eagle F1 GSD3 on mine
Cheers,
Robin
panesar_e30
Post Wed Feb 22, 2006 11:03 pm
use 205 50 15's they look much better, im using these at the moment with motorsort bbs's.
you can slam the car too with no rubbing issues, 195's will look to skinny an sit too far n the arches imo. :D
Cava
Post Wed Feb 22, 2006 11:09 pm
I'm running 15" bbs on both cars (same model, age etc), one has the standard 205/55, the other has 205/50. If it's any help, the 205/50's feel better.
320Touring
Post Thu Feb 23, 2006 11:57 am
orangecurry wrote:get away with.... that's up to you
205/55/15 = 606.5mm
i've got 195/50's on the touring-doesnt seem to affect handling too much! and as for speedo-seems to be ok.
jonbuoy
Post Thu Feb 23, 2006 2:38 pm
Nice one lad's, you are all a great help :thumb:
