Side Skirts; has anyone ever fitted these?
stephenw
Post Mon Feb 20, 2006 9:03 pm
Hello E30 owners,
I am thinking of putting side skirts on my 1993 316I tourer. I understand you need to drill 6 holes for the butterfly clips that hold the upper edge tight to the car body. How do you know where to drill the holes? and what size drill? can you buy a template?any advice from someone who has retro fitted these would be welcome
thank you Stephen.
316eyes
Post Mon Feb 20, 2006 10:39 pm
Not certain, but I think you can still get a template from the stealers.
eko
Old timer
Post Mon Feb 20, 2006 10:47 pm
I fitted these to mine recently.
I tried to get a template from the dealers and was told not available.
To fit them,the easiest way i could find,was to first clip on the bottom edge,push the skirt in untill the pegs just touch the sill.
Now(i used electrical screwdriver)mark a dot in the place the peg touches.
I then used a 1.5mm drill to carefully pilot these holes.
Then used an 8mm drill to allow the plastic gromets to plug in.
The rest was easy,came out straight too :)
316eyes
Post Tue Feb 21, 2006 12:04 am
eko wrote:I fitted these to mine recently.
That's what's good about the zone.............someones usually done it before!
stephenw
Post Tue Feb 21, 2006 7:08 pm
Thanks for the advice.
I've seen some for sale on ebay with bottom clips, top butterfly clips missing, though I imagine you can buy these seperate at the dealers.
I,m not sure how you managed to mark the holes though as I thought the butterfly clips went behind the skirts when fitted so how did you manage to mark up for those?
Stephen
eko
Old timer
Post Tue Feb 21, 2006 7:12 pm
No its simple.
The butterfly clips,clip on to the skirt first,making marking the holes simple!
The clip has a sharp pointed end making it easy.
stephenw
Post Tue Feb 21, 2006 7:23 pm
I see.
I wanted to work out if the job is possible before buying them.
I have a blue 93 316i tourer and I think they look better with the black skirts, seems that BMW only fitted them to earlier 325i's though as i've never seen the later 316i/318i 'lux' tourings with them.
One thing I have noticed is that there seems to be 2 or more different patterns of black skirts? (excluding M-Tecs). I'm not sure if there is also different lengths for 2 doors 4 doors and tourers?
thanks again Stephen
eko
Old timer
Post Tue Feb 21, 2006 7:30 pm
well mine came off an 1988 tourer and are now on my 318is,so i think that means they are all the same!
Kos
Post Wed Feb 22, 2006 1:42 am
i used the correct under clips, a self taper screw on each end and bonded it on, didnt fance drilling in to the sills as its just asking for rust probs in the futur !!
