Bleeding the PAS?
eko
Old timer
Post Mon Feb 20, 2006 12:41 pm
Is it nessarsary to bleed the power steering pump?
Fitted a tested pump at the weekend,tensioned the belt,toped up fluid and tried it.
Steering is working fine,but when turning on full lock either way it screaches as if the belt is slack :mad:
Does it need bleeding?
How?
Thanks in advance :)
optima
Post Mon Feb 20, 2006 12:47 pm
it is normal that it makes that horible sound
TheDutch
Post Mon Feb 20, 2006 12:48 pm
Changed my rack a couple of weeks ago and followed Bentleys bleeding instructions which was to turn from lock-to-lock 10-15 times with the engine running, topping up reservoir as you go. This worked well, but the system is self-bleeding, so I don't know what more you can do than just use it and see if it sorts itself out.
eko
Old timer
Post Mon Feb 20, 2006 12:53 pm
Optima-definately not normal,my 318is doesnt do it!
TheDutch-Thanks mate,to be honest i did more or less that yesterday when i fitted it,just been and tried it now and its still screeching,but ive got to take the car back to the owner this afternoon so thought id just check.
Think ill go and have another try now,thanks mate :)
stuartgallafant
Post Mon Feb 20, 2006 12:54 pm
if the belt screeches on full lock then the tension is too tight. i tightened my belt too tight and it made that horrible sound.
you should loosen it, as this can cause problems with the bearing on the pas pump pulley/shaft
