525e Booster and Master cyl into E30
WerkdE30
I can get a booster and master cylinder very cheap the owner claims it will fit into an E30 is this worth doing? anyone done it?
jmc330i
The 525e (E28) brake servo (booster) is the same as the E30 servo, so thats not really worth changing unless yours is knackered.
The E28 Master Cylinder is a 23.81mm one (same size as E30 M3) which is bigger than the normal E30 M/C (21mm ish??) so it would give you a frimer pedal.
You can fit a bigger 25mm M/C from an E32 750i (a common upgrade for M3 owners) so maybe the E28 one will also fit the E30.
It might be worth a try if its that cheap, but you would need to check the thread size on the M/C for the pipes. If both are 10mm threads then it should fit.
Also if the holes for the brake pipes are in different places compared to the E30 M/C then you would also need to mod the brake pipes to fit - this may not need doing as the 750i M/C is a straight swap in a non-M3 E30 so again maybe the E28 one will be.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
To achieve what?
