e30 320i headlight washers and wipers not working
m3mpower
Sun Feb 19, 2006 4:42 pm
hi, i have a e30 320i SE with headlight washers and wipers, but unfortunately they dont work..
any idea what the problem is??
thanks
Grantley
Sun Feb 19, 2006 6:58 pm
If you have a look on here theres a headlamp wash/wipe article, hope it helps !
http://www.totalbmwmag.com/Pages/Tech.html
m3mpower
Sun Feb 19, 2006 9:03 pm
hi, thanks for the info, i will have a look at it later...
cheers
WARLOCKM42
Sun Feb 19, 2006 9:34 pm
I would check the fuses first
Sun Feb 19, 2006 10:48 pm
WARLOCKM42 wrote:I would check the fuses first
They're on the same fuse as the main wipers and washers, so not a possibility.
m3mpower
Mon Feb 20, 2006 1:01 am
i've checked the fuses, they are all fine...
