hi, the windscreen washer blades on my e30 320i work fine, but no washer fluid comes out even with a full washer bottle...
i have inserted a needle into the holes to unblock them but still the same...
i am checking the pipes all the way and the question i have is:
there is a white big tube with three small tubes linking the pipes on each side..i have taken it off and blown inside and no air comes out from the small three tubes, is it meant to be like that?
sorry if there is any confusion, a bit difficult to explain
windscreen washers not working
ad318i
yeah thats your problem its the valve for the washer jets, they go quite often on the e30's i got one oast week from bmw for Ԛ£3.81 the part number is
61661374978
when thats replaced they should work fine
61661374978
1989 Alpine White 318i 4 Door - Got Scrapped When I Was Abroad
1993 Metallic Green 316i Touring - Im Selling it before i move back to Greece, http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0239342139
m3mpower
thanks mate, i will replace the 2 valves and see what happens,
appletree
mine did the same not to long ago and also one of the holses had split inside the bonnet and was pissing water out.
m3mpower
appletree, did you have to replace the valves too?
The first question I would ask is, does the washer pump work? i.e. make a whirring noise?
WARLOCKM42
Chek the washer motor too its located in the water tank it has a small filter clean it not to have problems again if the motor doesnt work check the fuses
ad318i
excatly what mine was doing only noticed it when the bonnet was up!appletree wrote:mine did the same not to long ago and also one of the holses had split inside the bonnet and was pissing water out.
Washers shsre a fuse with the wipers, so that's not it.WARLOCKM42 wrote:Chek the washer motor too its located in the water tank it has a small filter clean it not to have problems again if the motor doesnt work check the fuses
m3mpower
hi, thanks everyone for your help, i have now replaced the washer jet valves and everything is working fine...
