318is Diff Questions
Pal318is
Post Sat Feb 18, 2006 10:26 am
Guys,
My Diff has finally given up on me and has started to whine :cry: :cry:
I have a replacement, but i've had it stood still in my back garden for the best part of over a year :oops: I checked the oil in it this morning and it's nice and clear. I have some questions that hopefully you guys can answer.....
1. If the the oil is nice an clean as it is, does that mean that it's ok??
2. The Diff was rusted from the outside, which I have cleaned up, will that affect it if it is good?
3. How is the Diff oil changed, I haven't got a clue how to do it??
4. Is it easy to replace the Diff, I have tools and a little bit of know how, but maybe not enough?? :cry:
5. Finally what numbers am I lookin for, to check the ratio on the Diff?
Any help would be greatly appreciated guys.....
Pal
Pal
Image[img]http://Image
Lordschleife
Post Sat Feb 18, 2006 6:01 pm
Diff for an iS should be the small case one (6 bolt i think?)
Ratio should be 4.10, this shoulod be on the metal tag on the diff - probably be rusty so you'll need to clean it to read it. If it has an S before the 4.10 then you're lucky and its a limited slip
I think they're fairly easy to replace, use a trolley jack to take the weight of the diff?
Cheers,
Robin
Dan318-is
Post Sat Feb 18, 2006 6:07 pm
a 3.91 will also work fine on an Is,
i would change the oil for good practice!
Lordschleife
Post Sat Feb 18, 2006 6:16 pm
But a 3.91 will be a medium case diff usually? Making it a bit more fiddly to fit
Cheers,
Robin
Dan318-is
Post Sat Feb 18, 2006 6:21 pm
Lordschleife wrote:But a 3.91 will be a medium case diff usually? Making it a bit more fiddly to fit
Medium case with 8 bolts yes, propshaft easily shortened im told; also diff can take a lot more abue than the small case ones
Pal318is
Post Sun Feb 19, 2006 1:25 pm
Nice one guys, but how do you change the oil??
Pal
Pal
Jamesb318is
Post Sun Feb 19, 2006 2:21 pm
There are two bolts on the rear of the diff cover. You will need a large allen key type bit to undo them. If rusty, may be worth cleaning out the bolt heads with a bit of WD40 etc so you dont round them out.
Make sure the diff is the right way up, and level. Undo the top bolt first (that way you wont drain all the oil and find the top one wont undo) then drain the oil from the bottom bolt.
Replace the bottom bolt - and washer (pence from dealer), and refill at top bolt until it pours out of bolt hole. Wait until the oil stops coming out of the top hole (make sure diff is still level) then replace top bolt+washer.
I normally use Castrol SAF-XJ.
Dan318-is
Post Sun Feb 19, 2006 5:08 pm
Were do you buy your oil james?
i cant find it anywhere except bmw; 40 quid for doing it they want!
Jamesb318is
Post Sun Feb 19, 2006 6:40 pm
'Buy' oil?!!! i find it in the drums at work! :eek: :wink:
Pal318is
Post Mon Feb 20, 2006 1:37 pm
Jamesb318is wrote:There are two bolts on the rear of the diff cover. You will need a large allen key type bit to undo them. If rusty, may be worth cleaning out the bolt heads with a bit of WD40 etc so you dont round them out.
Nuff Respek James.... :thumb: :thumb: :thumb:
Thanx for the feedback Guys, as before always appreciated.
Pal
Dan318-is
Post Mon Feb 20, 2006 7:02 pm
Jamesb318is wrote:'Buy' oil?!!! i find it in the drums at work! :eek: :wink:
How much for a litre winkeye
kevin316i
Post Thu Feb 23, 2006 9:17 pm
Castrol SAF-XJ is for limited slip diffs, its available form the main dealers only. Costs about 25 euro per litre. Small casing diff takes 1L.
Jamesb318is
Post Thu Feb 23, 2006 10:31 pm
I can check what a staff discounted price would be if you want? I cant really go filling up bottles with the stuff, doesnt really matter when its my car, but i dont wanna take the :piss: !
