e30 320i rear brakes problem
m3mpower
Post Sat Feb 18, 2006 12:26 am
hi, when i pull the handbrake, the car breaks only on one side,
what do i have to do?
thanks
Post Sat Feb 18, 2006 1:30 pm
Find out what's wrong with the handbrake on the other side, and fix it!
Hoggy
Post Sat Feb 18, 2006 3:56 pm
personally I would have a look at the suspect side,if there was nothing visually out of order like cables stretched or damaged start dismantling them,its not as daunting as it can sound,when you get them apart you then have the benefit of one working unit and one not, so you can at least make comparisons, its probably not the easy fix you were hoping for but cables and fixings would be my first place to check,hope you get it sorted,Boss
m3mpower
Post Sat Feb 18, 2006 7:14 pm
thanks for the info hoggy, i will do that and see what happens
