It's getting there, I'll use the 2L head and the original 525e block and pistons, the things over twenty years old and the crank only needed a polish.
I got pissed off with the shark at the local engineering shop who told me i'd need it totaly re-done and then wanted to rip me off for rings and bearings.
I'm sorting out the head now and just working out which is cheapest, drilled valve guides and oversized stems or just new guides.
Cheapest option is just to put the head back together and just bolt it on, it didn't sound too sad when i last heard it running. Chances are if i do that i'll be pulling it apart in a couple of months though
How's the 325 ? did you shift it ?
There is NO nucleus.
