Hi,
firstly I'd just like to say I am glad I am still an owner of an E30 touring after a little bit of a pant soiling time last Friday when a bit of black ice caught me out on the M4 slip road to the A329 near Reading! A few revolutions later I survived and even better the car survived too!
Anywhooo, back to the matter at hand. I need to disable the headlight wash function as it is pissing water away out of the wash reservoir and that's pretty useless with the wipers not functioning.
Anyone have any ideas how to easily disable it. I thought about removing the fuse but it shares it with the rest of the wash/wipe system.
Cheers,
Hitman
Disable headlight wash
sabrje
I know that piece of road and it is tempting to take that long bend at speed but I'm glad you and the car survived the spin
I'm sure it looked impressive to any onlookers.
To disable the headlight wash just disconnect the relay attached to the washer bottles. Its that simple.
hitman
Cheers,
There was a guy who had just spun himself so he had a ringside seat, although he was probably getting ready to dive for cover, I know I would have!
I'll give the relay a go later on. Cheers for that.
Hitman
Hitman
Gwynleym10
Glad your ok after the spin!
I think you need to realise something, you shouldn't be wanting to disable the system, but rather finding out how to fix you problem!
It is quite possilbe that all you need to do is open up the motors and reagrease the insides, this will enable the wipers to work!
Get things to work man! its a bmw not a ford/vauxhall etc etc where you HAVE to bypass functions...
Morat
Hmm, I've got a set of wipers that don't seem to move at all....
Is regreasing the first step or should I be looking elsewhere?
The headlight wash/wipe neither washes.. nor wipes atm
Gwynleym10
have a look at this mate
http://www.totalbmwmag.com/HandsOn/TechAug01.PDF
hitman
Agreed, I should fix it, but finding the time at the moment to is difficult. I promise I will fix it soon, but in the mean time it will be the quickfix, especially with the dirt that gets kicked up of the road means excessive use of the wash/wipe system at this time of year!
gareth
i've removed mine along with the intensive wash system, but that's cos i have a airbox in the space the tanks normally go. a fair trade off to get a 3.5 in there though!
Morat
Hmm, it seems that only one set of wipers (passenger side) is working on mine, and none of the jets
Skip
Excellent link!Gwynleym10 wrote:have a look at this mate
ex-325i Touring
RobChase
Found this link whil epassing thru and decieded to give mine ago with the link. But after I get the cover off the units I cant get the backing plate off the motor. The chrome on in pic no 07 in the article. Ive tried everything. I can get it out partly but just stops.
Has anyone done this and if so HOW?
Hi Dee Lee Hoo Neighbourino
Once the output shaft and rack are out the way, then it should just fall out, as far as I remember.
oze30
could someone email me the article as my firewall prevents me from doing so!
