oversize head gasket
popupstands
Post Sun Feb 20, 2005 6:35 pm
does anyone know where I can purchase a 2.05mm head gasket (stock is 1.63mm)
Ant
Retired Team Member
Retired Team Member
Post Sun Feb 20, 2005 7:47 pm
go to the stealer, they do an oversized unit to restore the stock CR following a head skim/decking
cant recall the dimention but I do know its drops an 8.8 CR down to about 8.2:1 CR
HTH
Turbo-Brown
Boost Junkie
Post Sun Feb 20, 2005 7:48 pm
Think a company called SPESSO do thicker and uprated head gaskets. You can get them from Demon Tweeks. Not 100% certain they cater for BMW though. Mabey worth a try? :)
Guest
Post Sun Feb 20, 2005 7:55 pm
A company called felpro do a better head gasket, this is the muts nuts.
popupstands
Post Sun Feb 20, 2005 9:10 pm
do you have details on who sells felpro gaskets in UK
Guest
Post Sun Feb 20, 2005 9:37 pm
I will find out tommorow for you but these are whats used in the racing M3`s and high powered cosworths.
popupstands
Post Sun Feb 20, 2005 10:56 pm
Thanks mate
Andy325i
Post Sun Feb 20, 2005 11:11 pm
I have seen metal headgaskets for Rover v8's, does anyone make such a thing for Bimmers? Do they work?
Guest
Post Mon Feb 21, 2005 12:16 am
Felpro is the item your refering too, it is a tripple layer item, rubber, metal, rubber.
popupstands
Post Mon Feb 21, 2005 9:44 pm
so does anyone know where I can purchase felpro head gasket from?
e30_Turbo
Boost Junkie
Post Tue Feb 22, 2005 12:44 pm
http://www.sampsons.co.uk/
These will custom make gaskets, even do the metal reinforced type, although thickness is only 1.5mm.
The owner is going to have a look through his books and see if he can source the FELPRO ones for us......if they are a reasonable price it might be worth all of us turbo e30's to get one, (group buy!) I'll post what he says when he calls back.
popupstands
Post Sun Feb 27, 2005 9:17 am
any luck with felpro details
e30_Turbo
Boost Junkie
Post Sun Feb 27, 2005 11:13 am
Never heard back, or missed the call....I'll send them an email......
