Hi,
Gotta leak in the drivers side of my cab...rear and front footwells...the front window duz sit a bit low and not a good seal there...so thats most obvious thing (still waiting on contact for new mechanism...if any1's got leccy window mech PM me...)...but is there anywhere else water comes in???
Cheers Dom
water water everywhere
Widge
Can't you ajust where the window sits when it's fully up? So that it makes the correct seal.
domross
No, unfortunately the mechanism is knacked ,the cogs are missing/worn as it gets to the top of the range so it's beyond adjustment now...left wiv bout a cm gap...lots of wind noise & now water...
bigun
you really need to look at all possible points of entry but i would get yourself down the breakers an sort your window out check all seals
