Bad idle when cold...help!
Ratfink
Mon Feb 13, 2006 5:29 pm
Hi guys,
When i start my 316i in the morning or from cold it idles badly and the rev counter needle jumps up n down. Sometimes when you pull away it stutters aswell.
Within 30 seconds the problem goes away.
Any ideas? Im told it could be the temperature sensor, can you test for this?
toby
Mon Feb 13, 2006 8:59 pm
ok I'm sure some other people will give you a more accurate idea but my tupence is
has the car been serviced? the basics need to be checked first.
the poor cold running may be a problem just caused by a weak fuel mixture
good luck sorting it - shouldn't be anything too expensive
Ratfink
Tue Feb 14, 2006 12:25 pm
It does sound like that blue temp sensor...i'll give it a try.
Tue Feb 14, 2006 9:00 pm
Ratfink wrote:Hi guys,
Do you mean the rev counrter jumps up and down as the revs rise and fall with the bad idle, or like it had a bad connection?
Ratfink
Wed Feb 15, 2006 9:22 am
Sorry i meant with the bad idle...it goes from about 500-1500 rpm then you drive up the road and its fine.
Im wondering if that temp sensor is to blame
Wed Feb 15, 2006 9:39 am
Blue temp sensor is a strong possibility, but take off and check the large rubber hose between the air filter assembly and the throttle body, and check it very carefully for splits.
Ratfink
Wed Feb 15, 2006 2:37 pm
Ok will do...i did have a quick look at that and it seemed ok but i will double check it.
