Recurring crank no start issue
bebus
Post Thu Jul 30, 2026 7:19 pm
Hi Zone,
I'm looking for some advice on where best to re-visit the below issue which I thought had been solved.
For some time I have had pretty random, intermittent crank no start issues.
Car: 1987 325i, M20 engine
Description:
  • The crank no start issues seemed to come up at any time - even if I had just started and driven the car without issue, the next start could be crank no start (or not)
  • Most recently the car refusedcranked but refused to start at all
  • After doing some investigation, I ended up replacing the DME relay (brand new OEM). The fuel pump relay had also already been replaced previously)
  • The car then started fine - problem solved I thought
  • Now after approximately 6 weeks - the issue is suddently back after successfully starting it earlier on the same day..
  • When I bridge the DME relay, the car starts fine..
  • When I try to start with the DME relay plugged in, I can hear that the relays don't seem to be engaging.
Any tips on what to check?
Post Sun Aug 02, 2026 8:08 pm
Do you still have the original DME relay? If so, perhaps try swapping them over...
bebus
Post Fri Aug 21, 2026 9:04 pm
I do still have the original relay, but I swapped it out as it got to the point of persistent crank no start with the old relay.
Will have to check if anything changes with the old relay.
