Hi Having to replace 63 litre fuel tank due to internal rust. Got the tank out fine no problems. However the 8mm feed pipe that runs along the top of the tank is very badly kinked. I don’t want to cut it and put rubber on as it’s hidden and high pressure. I need to put a new one on but I can’t find a part number anywhere on the BMW parts catalog or realoem. Can any one help either with a part number or good used pipe off a breaker.
Cheers David
Fuel Feed Pipe part number
Snowey
