diff tags
player6
can anyone tell me what diff i have by the tag number
it is S3,25 1801
it is S3,25 1801
scot 328i with 260bhp
dazleeds
- old skool raver
i would say a 3.25 lsd
thats what the no's mean anyway mate
the s denotes lsd and the first 3 no explain the ratio
hth
not heard of that ratio tho
hth
www.oldskoolfantasy.co.uk
Dan318-is
Edit: see belowdazleeds wrote:i would say a 3.25 lsd
hth
player6
do you know what it comes off
player6
its smaller than my 3.91 diff
Dan318-is
i remember
standard m3s had this diff
player6
i take its a small casted diff then
Dan318-is
Yes it will be small casing i believe
Andy335Touring
M3 is big case i thought ?
8 bolts holding on the back cover is a big case ?
Dan318-is
i said big case didnt i?
edit: i think i am going mad
player6
whats the diffence in the big and small cased diff then
Andy335Touring
I think the small ones won't handle the kind of torque your getting from your engine for very long ?
Dan318-is
as suggested the size, small cases have 6 bolts at the back large cases have eight; although large cases are actually medium cases because 5 and 7 series diffs are huge
large case diffs are meant to a lot more robust and take a lot more abuse than the smaller ones i think
Simon
S3.25 is a medium case LSD from an M3, M3's also had 3.15's, found on Evo II and sport evo.
player6
t think this one came off a 323i
Dan318-is
The 323i came with a 3.64 as far as i remember??
Simon
Not sure about 323i, but 324td touring came with a 3.25 too.
dazleeds
- old skool raver
u lucky sod player
must check and see whats on my 323i
no plate
so need an accurate manual way of finding out and i cnt drive it
any ideas??
no plate
any ideas??
suppose if you jack it on one side and try to turn the wheel and it won't turn then that would suggest it is a slipper daz, assuming the old girl hasn't seized the handbrake on etc?
then it's all about counting how many revolutions of the wheel to the prop
jonb
that diff is from a 323i with a dogleg box,. hence the high ratio. these are quite rare, but due to that fact they are small case they are not as strong as the 8 bolt m3 varient.
