Car still has pover when key is removed
DMW
Post Wed Aug 28, 2024 12:14 pm
Hi I hope someone can help I bought a new E30 318 Coupe,the problem I have is that when you remove the key from the ignition, the electric still work ,indicators lights radio, what should I look at first in my diagnosis process ,thank you in advance
my fleet
3 e30 tourings 2 316i 1 325i
E30 318i red coupe
e36 328i sport silver
e36 320i cab black
e39 540i black
e31 850i
fixedwheelnut
Post Thu Aug 29, 2024 11:09 pm
Check ignition switch is actually switching off.
Has it had any aftermarket wiring, alarm or stereo? they are prime suspects for incorrect connections.
You do know the electric windows should work when the front doors are open, a comfort relay powers them up when the door is open.
DMW
Post Fri Aug 30, 2024 9:45 am
fixedwheelnut wrote: โ†‘
Thanks for the reply,it has a Clifford alarm which does not work ,will check the ignition switch first ๐Ÿ‘
my fleet
E30 318i red coupe
e36 320i cab black
e39 540i black
e31 850i
