I have just bought a mtech 2 wheel to fit to my 89 sport to replace the mtech 1 fitted but I am having trouble fitting it.
I thought it was a straight swap as the car is an mtech 2 version but the new wheel will not fit and does not seem to have the splines for the steering lock to fit into.
The steering lock mechanism seems to be in the way
Do I require a boss to fit this wheel?
any help is appreciated.
Jason
MTech II Steering Wheel Fitting
Cloggy Saint
Gwynleym10
- Contact:
It should be a straight swap providing you have the correct mtech 2 wheel.
Ones from E36 DO NOT FIT and you can't do anything about it. Also they are not worth much...
- jas325sport
Was sold this as an E30 mtech.
got it off eBay from BMBITZ
Cloggy Saint
- jas325sport
have just checked part no's on ETK and looks like this is a E36 wheel aaaaarrrrrggggggghhhhhhhh.
I will have to send it back.
I have noticed BMBITZLTD have another wheel up for auction the same as this one also described as E30.
Cloggy Saint
- jas325sport
this one was soley described as for E30 so beware of the other advertised.
lets be careful out there.
(hill street blues repeats on more4, nuff said)
Its even more confusing buying them for E34s. The early E34s, from 87-91 use the E30 spline, and don't seam to have airbags.
The E34s from 91-96 have the later E36 spline.
So you can buy an E34 MTech 2 and it may or may not fit your E30 depending on the year and other factors.
