What's this wire please
Corasdad
Can anybody tell me what this wire is and where it should be connected, I have also pointed out where it goes to but I can see to be able to see what it is
Contours
Looks like the cylinder identification wire sensor which should be connected to plug lead no.4 but has been left disconnected there.
https://www.e30zone.net/e30wiki/index.php/CID
Corasdad
Thank you is no4 closest to the driver or furthest away from me the driver
Contours
Closest to you the driver , No 1 is closest to the radiator. No4 plug lead is the 2nd lead down attached to the distributor cap as you look and it is there that the impulse sensor attaches to the plug lead.
