Power Steering Banjo Bolts
G00GIEE
Sun Jan 15, 2023 9:01 pm
In the process of replacing the knackered M40 engine in my 316i, I've misplaced both of the banjo bolts from the power steering pump.
It's another M40 gone in so I need to find a pair of new banjo bolts and after searching, I have no idea what size they are and so I am unsure where to find the bolts and the washers around them.
Can anyone help me? Does anyone have some or know where I can find the appropriate sized components?
fixedwheelnut
Sun Jan 15, 2023 9:48 pm
Part numbers on Real OEM.com here ;
M14 x 1.5 x 26 32416852469 still available
M16 x 28 32416783887 no longer available but sure there are others that fit Think a 1 series is the same 32416852470
https://www.realoem.com/bmw/enUS/showpa ... Id=32_0092
madiran
Wed Jan 18, 2023 8:38 pm
I have just replaced the power steering pump and intake manifold hydraulic pipe on my '92 E30 318i M40 Touring , the banjo bolts are : hollow bolt M14x1,5x26 32 41 6 852 469 and hollow bolt M16X28 32 41 6 852 470 you will also need the crush washers to fit, two of each: Gasket ring A14X20-ALMG 32 41 1 129 986 and Gasket ring A16X20-CUSN 07 11 9 906 463 , Torque the large bolt to 30 ftlbs/ 40Nm and the small bolt to 26 ftlbs /35Nm. I ordered the parts from https://www.hubauer-shop.de their service was impeccable.
https://www.realoem.com/ and http://bmwfans.info/parts-catalog/
