M20 conn rod bolt head socket
Etharla
Post Sun Jun 19, 2022 11:33 am
Good morning everyone,
I’m in the process of preparing for a full engine rebuild. I’m ready to remove the pistons before sending the block to the workshop for a once over. Does anyone know what head type is on the bolts that hold the conn rod cap in place? I thought it was an E torx head but there’s a lot of splines (if that’s even the correct terminology). I’d be worried if I used a standard e torx socket that it might strip either the socket or worse, the bolt head.
Any advice?
Thanks,
Joe
onthames
Post Sun Jun 19, 2022 3:58 pm
It's a standard 12 point that you find on the back of a spanner
Etharla
Post Sun Jun 19, 2022 9:14 pm
onthames wrote: ↑
Thanks. How the f@*k did I miss that one? I was searching everywhere looking an answer to that. I assume I can just buy a 12 point 10mm socket then…
Cheers,
Joe
onthames
Post Sun Jun 19, 2022 9:41 pm
Etharla wrote: ↑
onthames wrote: ↑
Cheers,
Joe
I did exactly the same thing.. Don't worry. And yes you can!
parkin10
Post Sun Jun 08, 2025 4:40 pm
Did you replace these bolts?
