Removing old temp sensors
paultv
Post Mon Apr 18, 2022 10:48 am
Anyone know if there are "Blind Plugs" that I can insert in place of these two old unused electric fan sensors which are now starting to leak.
Both on the thermostat housing. Also I'm not sure if all the sizes are the same - M12 1.5 appears to be the size of the other sensors - ??
Paul :-)
Post Mon Apr 18, 2022 1:47 pm
Is that the same size as a wheel bolt?
Cut it down to suit :D :D
flybynite
Post Mon Apr 18, 2022 3:44 pm
Plenty of plumbing plugs that size
Just put M12x1.5 blind plugs in google and lots came up, Not sure if both are same size though?
https://www.google.com/search?q=m12x1.5 ... 50&dpr=0.9
paultv
Post Wed Apr 20, 2022 6:33 am
Turns out they are 14X1.5...two of them and the temp sensors are 12X1.5......thanks guys...didn't want to remove them without anything to replace with.
Paul :-)
