Car temperature never goes above 60
Kalimsnor
Post Tue Mar 15, 2022 8:45 pm
Hi guys,
My mechanic replaced my VISCO last year, and a little bit before that we have put in a new thermostat and thermostat housing (it was rusted out).
Not sure when it started, but my car temp never goes to 90. Not even after hours of driving. The heater blower also doesn't get really warm. I have an infra -red heat-tester which tells me the coolant lines and everything is below 65 celcius.
What can this possibly be? Where to start looking?
Greetings!
Dlb26
Post Tue Mar 15, 2022 9:41 pm
Check the thermostat, it could be stuck open, the wrong one or less likely but not impossible not even fitted. I presume your mechanic is more reputable than that though.
Kalimsnor
Post Wed Mar 16, 2022 5:23 am
Excuse me, forgot to mention that. We have recently put my thermostat in boiling water to test if maybe it would be better to use a high-duty thermostat. It opened just fine and did everything it should do.
Kalimsnor
Post Sat Mar 19, 2022 9:31 pm
Bump, any ideas?
BenHar
Post Sun Mar 20, 2022 6:00 pm
It can only be the thermostat.
Six cylinder engines need an 82 degree stat and four cylinders 88.
Ben
paultv
Post Mon Mar 21, 2022 6:18 am
Agreed....buy a new BMW item, under 30 quid, and not a 3 quid Autodoc piece of crap, this is an often over looked and very important part for the continued health and longevity of your engine.
Paul :-)
