Charging issues
K1987n
Post Sun Feb 27, 2022 2:15 pm
Hi everyone
Having charging issues with my 1989 320i, only getting 10v at the battery when the car is running, I'm getting 14+ volts from the alternator (both terminals). I'm thinking possible bad wire between alternator and battery? Just wondering if there's any common culprits? Where should I start looking? TIA
fixedwheelnut
Post Sun Feb 27, 2022 8:18 pm
Possibly wire from Alternator to battery or a bad engine earth, use a voltmeter to measure volt drop across the lines, it shouldn't be more than 0.5v drop or you have a bad connection/High resistance
K1987n
Post Sun Feb 27, 2022 8:22 pm
Thanks mate I'll try that tomorrow 👍
