Depin Bosch Connectors
whizlceks
Post Tue Nov 30, 2021 3:35 am
Excuse my ignorance, but is there some trick that I'm missing? I'm trying to depin and repair a few of the 2 & 3 pin Bosch connectors on my '87 325i. I have all the depinning tools I could ever need, and nothing seems to be working. The front openings are the "T" style, which should be a single snap terminal, correct? Only the "+" style openings should have the top and bottom snaps, or am I mistaken? I've tried getting every tool into these things, and so far all I've done is break a few wires. Failing miserably, and any help is appreciated!
NauticAl
Post Tue Sep 06, 2022 12:13 pm
Hi
How did you get on?
I have the same problem fitting an E34 2.5 engine into my 1984 323i. Lots of wiring loom adaptation to do.
I have cut a spare bosch plug in half to try and work it out but I can't get both lock tabs to release.
The Utube info all shows the connectors with the + shaped holes.
Al
