325iSE with 139k on the clock
Getting the following work done:
Timing Belt, Tensioner Pulley & Water Pump all replaced (sticker in bonner says replace at 143k)
Dodgy Handbrake Fixed
Service 1
Anything else (minor ie not expensive!) I should get done or checked out whilst she's in to ensure top spring / summer driving?
Ta
Going Into The Garage Tomorrow
Simon
Could ask for the gearbox and diff oil to be replaced, shouldn't add much to the final cost.
Inspect the dizzy and rotor while they are removed, as if they are worn, can loose power.
Also change the sensors while they're under there, blue and brown ones located in the thermostat housing.
