I checked at the bulb holder and there is no voltage across terminals, Checked the fuse (according to Bentley it is Fuse 21).
Interesting here as last year I had a problem where my instrument cluster tried to catch fire whilst removing it (I always take the battery off now, even though I had an auto electrician check the wiring and found a short where the new immobiliser/ alarm was fitted).
I always wondered why the fuse didn't blow, now I know, some arse had put a 30 Amp in there instead of the 7.5 it should be. Now has a 10 as I couldn't find a 7.5. (There was also slight scorching on the fuse holder
Anyway, the fuse is alright but still no light working/no voltage.
I couldn't find the switch for the boot light, so any ideas where it is or of any common faults with these lights?
