Gearbox and Diff Oil - 325i Auto
Bavarian1988
Post Mon Oct 25, 2021 11:47 am
Hi guys
Would anyone happen to know which oil is recommended to use when replacing the gearbox and diff oil on my 1988 325i Auto Cabriolet?
I carried out a VIN check on the vehicle and it showed that it has a 25% LSD?
Any suggestions will be greatly appreciated
paultv
Post Mon Oct 25, 2021 11:59 am
Use this for your LSD
Syntrax Limited-slip SAE 75W-140
Not sure about the auto box - anyone?
Paul :-)
Bavarian1988
Post Mon Oct 25, 2021 12:17 pm
Much appreciated Paul
Yes just need to know the oil for the gearbox
BenHar
Post Mon Oct 25, 2021 7:14 pm
Bavarian1988
Post Mon Oct 25, 2021 7:25 pm
From the Wiki page on the site, it states that automatic boxes should use 'Castrol Dexron III' however this has now been replaced with 'CASTROL TRANSMAX ATF DX III MULTIVEHICLE.'
Is someone able to confirm?
Many thanks
flybynite
Post Mon Oct 25, 2021 8:02 pm
Many thanks
Haven't got or had an auto e30 but just put '88 325 into Castrol oil finder and it comes up with
Castrol Transmax ATF DEXRON®-VI MERCON® LV Multivehicle
Alternative
Castrol Transmax ATF DX III Multivehicle
So I guess you could use either
tha881
Post Mon Oct 25, 2021 8:59 pm
I would double check the LSD is still fitted, although it was fitted from new it could have been swapped at some point
Post Mon Oct 25, 2021 10:36 pm
Filtering down further on the Castrol site it looks like only Castrol Transmax DX III meets ZF transmission spec. E30 only used auto tx made by ZF. Up to now I have only used Dexron III spec oil. Do not forget to do a proper service you need to change the filter as well.
Bavarian1988
Post Mon Oct 25, 2021 11:32 pm
Thank you for all the suggestions guys, much appreciated.
oilman
Zone Oil Advisor
Post Tue Oct 26, 2021 9:13 am
Just a Dexron II or Dexron III ATF for the autobox, does not have to be Castrol but stick to a reputable brand and all will be good.
Cheers,
Guy
Use the code E30Z and get 10% Club Discount
oilman's website for engine oil and much more - register for news and offers
email: sales@opieoils.co.uk
phone: 01209 202944
Bavarian1988
Post Tue Oct 26, 2021 8:19 pm
Thanks oilman
