The car goes great and is fairly clean but previous owner didn't know much about the setup as he didn't build it. This leaves me with some guess work so I can refresh everything with the right replacements parts as required.
The main thing I'm trying to get sorted first is diff and fuel system overhaul, new lines and fuel tank. I already got most parts from BMW for overhauling the fuel system and I'm going to add a standard in tank pump, up to a swirl pot with a 044 pump and a fresh fuel pressure regulator and guage to make sure I have 5 bar and in preparation for turbo charging later on.
For the diff I'm not sure what will fit because I'm not sure which rear end I have, from researching I would guess it's off one of the Z3 models. I want to run a quaife LSD because it won't require much servicing and will work great without being overkill or noisy.
I need to figure out what diff I can use, I think any 188 medium will work but not sure? Could I just get any Z3 standard diff in the desired ratio and rebuild it to make it an LSD by swapping the internals with the new quaife part? I'll attach some picks of my rear end and current diff for identifying what parts would bolt in. Thanks for any help in this
