Hi All,
Took car out for a nice long drive to Oxford in the beautiful weather. Was so hot even with the roof down that I had the fans on coldest setting (non-AC) and full blast.
On the return leg the fan/blowers completely shut off and would not work on any settings.
Could this be a blown fuse in the first instance or would it more likely be the heater blower/matrix?
Fan stopped working
Elsalmon
Any thoughts?
1990 325i Convertible
Tzantushka
Blower might have shat itself.
Fuse likely - but also check the blower resistor (although when the blower resistor soils itself it commonly works on high speed only)
Contours
Likely a blown fuse if the fan was sticking somewhat and drawing more amps than the fuse can handle.
