Steering column knock
paultv
Post Thu Jun 10, 2021 10:47 am
I've developed a knock im my steering column when I hit sharp bits of bad road at lower speeds. The entire suspension is new and the knuckle joint is solid.
Can only find a kit for the E36...any thoughts/ suggestions? It's making me crazy!
Paul :-)
Post Thu Jun 10, 2021 1:17 pm
Im sure you can buy the bearings from BMW still
paultv
Post Thu Jun 10, 2021 1:45 pm
Thanks I'll check it out !
Paul :-)
paultv
Post Fri Jun 11, 2021 8:57 am
You are right almost everything is available - cool, now I have to open it up and find the play...
almost finished the rear quarter - the good weather helps with the paint!
Paul :-)
