Wiring plug terminal ID help
T_Dub
Post Thu May 27, 2021 12:55 am
Hi all,
Looking through my loom and there are a few terminal plugs that were out in the elements and they crumbled when I took the car apart. The terminal ends inside seem fine. Looking for the part number on the blue guy, nothing on realoem. Seems like these blue ones are used for the horns and the connection to the windshield washer heaters.
The two black ones are 61131378416 and 61131378408.
T_Dub
Post Thu May 27, 2021 1:18 am
From my research maybe it's 61131378402. But those are grey. At least the shape of the plug looks correct.
T_Dub
Post Thu May 27, 2021 2:18 am
Ok never mind, I got it haha.
Weird that most of these aren't on realoem.
Blue one is 61131378402. Not sure why they changed the colour. 90 deg version is 61131378418. Going to need all 4 of these. Horns, fogs, washer bottle, speed sensor, and fuel pump/sender.
Post Thu May 27, 2021 3:10 pm
Check out Jon/Mark at Cotswold on here ,they are superb mate !!
Post Thu May 27, 2021 6:49 pm
It's a good ideal not to try to sort out the part numbers for these obscure bits, and to leave it to the dealer to identify from your description. That way, if the wrong part turns up, it's the dealer's fault and not yours.
T_Dub
Post Thu May 27, 2021 7:00 pm
Good tip!
