TIMING CHAIN ON A E-30 318is (1990)
Demlotcrew
There is a heat sheild. It covers the ignition wires that run down the side of the head.scooby wrote:Hi people !! need some help here !! ,I have a problem with my 318is a bloody awfull rattling noise coming from the front of the engine,some times i swear i sounds just like a loose heat shield over the manifold but it aint,cause their aint no heat shield on the engine,ive been doing a bit of surfing around and think it could be the chain..any help greatly appreciated ...scooby[/b]
Andrew
- adamS
I don't think tensioners are expensive at all, something like Ԛ£35 according to the 318is bible:
http://www.esatclear.ie/~bpurcell/318is ... ntensioner
E30Mark
Glad to hear it was something simple.
But as Demlotcrew said, now go check the metal heatshield fitted around the HT cables, running along the side of the head. They ALWAYS crack through at the bolt holes, eventually you will have another annoying rattle! New shield is about Ԛ£3 from the dealer if required.
Took me ages to find this rattle on my iS last year....
PM for details
PM for details
Demlotcrew
Glad to see you on here mark!
Same problem here with the rattle from the front, noticed the heat shield too, what a rubbish design! and it's wafer thin. I've got the tensioner on order and I'll purchase a new shield also, just in case.
Just thought I would post up to say thanks for this info.
James Westwood
http://www.bmbits.co.uk BMW Parts at upto 50% off dealer prices
IT Security solutions Scotland
