Rust or Drain Hole?
MickoE30
Post Thu Apr 22, 2021 11:33 am
Morning,
Just wanted to check something - I see below hole in passenger side of boot when I removed the jack.
As it looks quite round, I was wondering if there should be a drain hole here (car is 1986 2-door), or if I need to get welder out?
Many thanks,
Michael
steve_k
Post Thu Apr 22, 2021 1:40 pm
Looks like someone might have had a problem with water collecting in the boot pocket & drilled a small hole to drain it put,
Quite a common problem caused by either blocked sunroof drains or failed rear light seals,
MickoE30
Post Thu Apr 22, 2021 2:46 pm
Thanks Steve, Yeah carpets were wet and rear light seals were totally shot.
I put new seals in last week, so hopefully that sorts it.
I will fill hole in...
steve_k
Post Thu Apr 22, 2021 5:57 pm
MickoE30 wrote: ↑
it should sort it,
when mine went i drilled the hole, painted in/round it with por15 then fitted a rubber bung just in case it happened again.
