hello,
so my passenger wing mirror is not working
changed the mirror with the driver side and it works.
changed couple of switches and no improvement.
when I operate the switch there is a clicking noise from the glove box
any input will be much appreciated..
thanks
wing mirror not working
bmw335icoupe
‘91 w124 Mercedes-Benz 300E
`13 F30 320D Saloon
`90 E30 320i Convertible
`91 E30 318i Convertible - sold
`06 E92 335i Coupe - sold
`13 F30 320D Saloon
Lemon98
Neither of mine work but then neither side has the original door or mirror so the wiring could not have been connected properly so I'm following this anyway.
1990 4-door 320i SE
Clicking noise is probably from the mirror. There's one motor in the mirror, plus a solenoid that determines whether the mirror moves sideways or up/down. What you are hearing is almost certainly the solenoid working as it should.
Each mirror has a 12 volt supply to the motor, which is live all the time the ignition is on. This wire is blue/white, and the one to the passenger side mirror passes through both A pillar plugs and sockets where the door looms plug into the body, so is subject to the same electrolytic corrosion that affects the well known central locking red/black wire. Problem can be in the A pillar socket either side.
bmw335icoupe
Hello Briannooore,
Thank you very much for such a constructive reply.
Will have a look at that, definitely!!
