320i juddering at low speed - solved
bmw335icoupe
Post Sat Apr 17, 2021 1:45 pm
Hello,
So ever since I got my 320 convertible 6 years ago the car would judder at low speed as if it wanted to stall.
It was particularly annoying in town, going up a small slope the car would judder so I had to help myself with clutch.
Even cruising at 50 mph was difficult.
I got desperate and opened AFM.
I think I adjusted the fuel air ratio.
Besically loosen the screw holding the spring. Make sure to mark the spring position. Then I turned the sprocket clockwise by two teeth.
If look really carefully you will see the old spring position.
The problem solved!!!! Now it is a joy to drive.
Hope the car is still mot friendly
‘91 w124 Mercedes-Benz 300E
`13 F30 320D Saloon
`90 E30 320i Convertible
`91 E30 318i Convertible - sold
`06 E92 335i Coupe - sold
Lemon98
Post Sat Apr 17, 2021 3:59 pm
Mine is doing the same juddering so will follow your steps and hope that it works for me!! :) thanks for sharing this
1990 4-door 320i SE
