hi there
couple of small things.im about to buy a new rear box for the touring
g and swedish do 2 types one at 36+ and one at 56+vat ones german the others not!
havent seen either type and was wondering what one to get?
also when cold the gearbox is a little notchy its ok after a couple of miles i was wondering if its worth changing the oil ?
thanks
Matt
Exhaust back box info and gearbox slight prob when cold
M5pilot
Get a Boysen back box, some of the guys here know wherre to get it from, it is simply brilliant.
DAN
I got a boysen backbox from GSF, its worth it
gazza
i fitted the gsf cheapo box Ԛ£32 for my cab ....i cant fault it, it replaced a euro car parts one that didnt see the year out ....pipe came out at wrong angle and joint was not correct it kept blowing then split
Cava
Regards the gearbox problem, changing the gearbox oil will help with this - even better if you get some synthetic oil.
MATTTT
thanks for the replies
i put the cheaper one on and it fitted perfectly
just got to get round to the oil change now
