Hi,
Would anyone know what the part number for the 6 bolts (and presumably washers) that go into the carrier (part no 51711913824)?
Thanks!
What bolts?
twenty
MunsterScot
twenty
Yup.MunsterScot wrote: ↑Sat Feb 20, 2021 4:06 pmHave you tried realeom?
https://www.realoem.com/bmw/enUS/select
If you look closely the photo I posted comes from a similar site (bmwfans.info, which is arguably better than realoem).
Anyway, the issues is that the bolts aren't mentioned in the carrier page.
No idea why its listed as 'rear body' because it fits at the front of the main heat shield, part number 1 in the below link, the heat shield fixing bolts also retain the brace, part number 2
https://www.realoem.com/bmw/enUS/showpa ... Id=51_1832
twenty
Amazing, thank you!DanThe wrote: ↑Sat Feb 20, 2021 6:43 pmNo idea why its listed as 'rear body' because it fits at the front of the main heat shield, part number 1 in the below link, the heat shield fixing bolts also retain the brace, part number 2
Ironically I’ve ordered the heat shield but only 3 screws as as I wasn’t sure what X meant. I’ll order 3 more.
I would expect the 'X' instead of a number just means its variable
