headlight Washer repairs/removal
MRBluffz
Post Tue Nov 03, 2020 7:45 pm
Hello,
I just picked up an E30 Touring with the headlight washer system. I can't for the life of me find anything online no how to remove it. I looked up the actual pieces and everything, and I understand that the rod is held in by a little nut, but at the same time I can't find it? I feel completely lost/useless. I feel like it should be obvious, but the only guide that I could find is so old the photos don't work anymore. Can anyone point me towards a photo/guide/video related to taking apart the headlight washer system?
I appreciate any assistance!
Dlb26
Post Tue Nov 03, 2020 7:57 pm
Do you mean the nut that holds the blades/arms on? If so it's under the cover in the centre. From memory once the blades are off you can remove the grilles then get access to the nuts holding the brackets on. You'll then need to remove the plastic cover from behind the headlight under the bonnet, disconnect wiring and hoses and remove the motors etc. Theres an article on the wiki about retro fitting which should have enough info to work from.
flybynite
Post Tue Nov 03, 2020 8:26 pm
Be careful taking the cover off, especially in this cold weather. The plastic just breaks and you won't get any more as they are NLA
tha881
Post Tue Nov 03, 2020 8:50 pm
MRBluffz
Post Tue Nov 03, 2020 9:49 pm
I thought I replied earlier, I dunno why it didn't work.
@DLB26 & @THA881 That wiki link is empty to me. nothing is there at all. It was one of the places I checked before posting a new topic.
@flybynite Thanks for the info, I am going to be super careful. Which cover are you referring to exactly?
flybynite
Post Tue Nov 03, 2020 10:10 pm
MRBluffz wrote: ↑
The headlight page linked to only has a downloadable PDF "media:headlamp_washers"
I am referring to the plastic cap covering the nut at the end of the spindle holding the double wiper arm onto the spindle.
The PDF above shows you what to do
