Cam Belt change 325i
M3kuksport
Post Wed Oct 28, 2020 7:39 pm
Doing the cambelt kit on my 325i, just follow the guide on here and no problems?
I have the water pump to do also. Any tips?
Post Wed Oct 28, 2020 10:42 pm
Make sure the water pump gasket is properly in place, and don't over tighten any bolts that screw into alloy.
Take the radiator out to give better access. Coolant will already be drained for the pump, so it's only a couple of screws and hose clips.
