New to this board as my son and I are trying to get an old e30 going again. Here is the history: The car sat for about 7 years so we had to start somewhere when the car did not crank. Now after all the parts below, the car will start for about 1-2 seconds cracks up then dies. You have to wait about 15 seconds and it will do the same thing over and over. I have searched and searched for answers. . Any help is appreciated, I am completely baffled that this thing will not start. Pulled the fuel line up at the engine and confirmed fuel is pumping. Not sure of the pressure have not measured it yet.
Replaced Parts:
- New Battery
New CPS
New Spark Plugs, confirmed spark
New Primary Fuel Pump, confirmed humming when starting
New Secondary Fuel Pump, confirmed voltage at startup, can hear it when starting
New Fuel Tank, old one was rusted
New Main/ Fuel Relay
New Intake boot
New Fuel pressure regulator
Rebuild Fuel Injectors - Tested & Confirmed working
Cleaned ICV per Youtube
Rebuilt AFM per Youtube, solding wire on contact arm etc
Checked and replaced all fuses in primary box, replaced fuse in the trunk
Thank you for helping us figure this out.
